Multisim and Ultiboard
Van der Pol oscillator circuit design in multisim
Hello experts
hope you all are fine
i am facing a circuit design problem . i am working on van der pol oscillator. i want to simulate its circuit in multisim but not getting desire results. any will help to debug error or give other cirucit dsign for van der pol , i will appreciate it  ..
i attached circuit diagram  and  multisim file of that circuit which i am trying to simulate
Message 1 of 10
(4,494 Views)
What is the problem you are seeing?
Message 2 of 10
(4,443 Views)
Thanks Mr. Nrojas . i have solved my problem .
actually some software simulation default setting was not working well . i changed that settings . and now it is working
Message 3 of 10
(4,437 Views)
Hello! I was wondering how did you solve your simulation of the van der pol oscillator? I have tried different things but I do not have the desired outcomes.
Thank you!
Message 4 of 10
(4,092 Views)
What  problem actually  you are facing in simulation?
Message 5 of 10
(4,083 Views)
Attached is my circuit diagram and I am sure I connect everything correct. Nonetheless, I do not have experience using this program that is why I think I am missing something but I do not know what it is.
Message 6 of 10
(4,075 Views)
in your given figure
negative supply of U4 IC  is not grounded . every voltage should have some reference, in this case it should be ground .
Message 7 of 10
(4,064 Views)
Besides that everything seems right?
Message 8 of 10
(4,046 Views)
yes circuit diagram seems okay . if it is not still working . kindly share pictures of simulation results or any prompted error if occur .
Message 9 of 10
(4,042 Views)
This is what I obtained. I do not know what I am doing wrong.
Message 10 of 10
(4,023 Views)
