Multisim and Ultiboard
VariRes / basso
Good day,
I want to use the variable resistor which can be found in the Multisim help (Basso SMPS Auxiliary -> VARIRES). But I can not find the element?
I thought it would be like in LabVIEW that you search through the help and when you find your element, that you want to use,you could click the "add to diagram" button.
Unfortunatly in Multisim it looks like there is only the helpfile itself. Is there a Toolkit or something like that, which i have to download?
Im using Multisim 12.0 and LabVIEW 2012
(5,568 Views)
It might be because you are running a tier of Multisim that does not have this family of components. Are you running a Student or Base edition?
Either way, I've included it for you in the attached circuit.
Max
(5,562 Views)
Thank you MaxNI,
I just wondered if there is also a "Vari Diode", so you can do a Co-Simulation with LabView?
The Vari Diode model need its own connector for each internal parameter. LabView could now try (with Levenberg-Marquardt) to fit the parameters. It works well with those VariRes / VariCap  elements! But I guess there isnt that kind of model for Multisim because it would be described in the help right?
Sorry for late reply
(5,523 Views)
