Multisim and Ultiboard
Vertical pin numbering in Ultiboard
I'm trying to create a footprint for a 168-pin connector, the pads have a dimension of 0.3x1.1mm with a 0.5mm pitch.
The problem is that I need it to have vertical pin numbering starting from lower left.
When I use "Renumber.." from the Tools menu I get the numbering in pairs of two. It works as expected with a lower pin count with different spacing/size.
Any ideas on how to solve this or what I am doing wrong? Naturally I want to avoid numbering the pins manually.
Thanks in advance
(4,572 Views)
Hello grafi,
Can you share an Ultiboard design that contains the newly created footprint?
This should make it easier to see what is going wrong and where it is exactly going wrong.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,524 Views)
