Multisim and Ultiboard
What situation refer to maxium drain current in the MODEL MAKER ?
hi ,all
     In the process of creating a spice model of NMOSFET , I didn't understand what situation refer to maxiun drain current ,DC or PULSE ?
     Thanks.
    leehiyu
(4,436 Views)
Drain current is an important parameter when the output load resistance is small. If the drain current is not big enough, the output voltage will be lower than what you expect. This may cause some founctional error.
Qiushi Shen
DSM Nanjing
NISH
(4,430 Views)
thanks ,i want to know ,in the process of creating nmosfet spice model ,the interactive table need a maxium drain current, what is the maxium drain current under any situation,DC or pulse ?
(4,419 Views)
The max drain current is an independent parameter with non-interactive impact by other parameter or operating condition. You can specify the value of  max drain current as you want.
Qiushi Shen
DSM Nanjing
NISH
(4,379 Views)
thanks sherman , i  will  specify it as the datasheet under pulse source .
(4,347 Views)
