Multisim and Ultiboard
When installing Multisim component evaluator, no features to install are found
The software I'm trying to install is Multisim component evaluator Analog Devices edition, version 11.0.1.  Everything has gone smoothly except that when I reach 'features to install', the list is blank.  The installation summary says 'No software will be added or removed', and the 'next' button does not highlight, leaving me stuck.  How do I get a working installation?
Message 1 of 9
(5,922 Views)
Your description sounds like you are using XP 64 and this is an OS that we don't support, Vista and Win 7 64 bit are supported.
Tien P.
Message 2 of 9
(5,905 Views)
Bingo, and argh...
Message 3 of 9
(5,899 Views)
on multisim 11.0.2
i have the same problem on a pc with windows 7 64 Bit.
if i try on a partition on the same pc with Xp Professional the installation is ok.
Message 4 of 9
(5,415 Views)
You should be able to install 11.0.2 on Win 7 64 bit,  this probelm only applies to XP 64 bit.
Tien P.
Message 5 of 9
(5,400 Views)
some one to help on how can i get those compents in multism 11.0.1 i have installed as evaluator
Message 6 of 9
(5,174 Views)
The component evaluator doesn't have the instruments you mentioned. You have to get the professional version for this instrument.
You can refer to the feature table from the following address for more information about the features in various editions.
http://www.ni.com/white-paper/5609/en/
Tien P.
Message 7 of 9
(5,134 Views)
thanks but how can i get the proffesianal version
Message 8 of 9
(5,129 Views)
Hi there,
You can find more information about the Professional Edition of Multisim at:
www.ni.com/multisim
Fernando D.
Message 9 of 9
(5,093 Views)
