Multisim and Ultiboard
Where can I find a 74HCT in multisim?
Where is the 74HCT in multisim or how do I add it?  Does anyone have the library with it?
Thanks.
(4,814 Views)
I have searched the Database and I am unable to find a 74HCT Family or Component with those numbers. There is a 74HC Family, if that helps much.
Have A Nice Day
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,810 Views)
Are you simulating or laying out a board.  For layout, just substitute a 74HC part with the same footprint.  For simulation, a digital sim should work out about the same as HCT but simulating the analog behavoiur of a pin attached to a net it might be different.
If you are not simulating but want the components to have the correct part numbers, I usually create new components by placing existing simialr device (say the 74HC00_6v) on the design then editing the component in the database, I change the name and delete the model then save in the user library.  It's faster than creating a new component from scratch using the wizard.
(4,791 Views)
