Multisim and Ultiboard
Where did Tek TDS2024 go in Multisim?
Using the trial version of Multisim, I had the Tek TDS2024 scope in several designs.  When I activated the purchased full edition (v. 11.0.775, db 11.0.b), by entering the serial number, I lost the ability to use the Tek scopes.  Why?
(3,074 Views)
Canyon Tree,
The vendor specific instruments are not available in Multisim Full, only on the PowerPro.
Is there a specific function you needed on the Tek scope? I've likely created (or could create) similar LabVIEW functions on an individual basis unless you needed all/most of the capabilities in this Tek scope. LabVIEW VIs would work in both Full and Powerpro.
I would also suggest calling into our sales team to make sure there was no confusion when ordering.
There is a link on the main ni.com/multisim page that says 'compare'. If you drill down it will show you features/limits in each tier of Multisim/
Pat N
(3,067 Views)
