Multisim and Ultiboard
Which Low noise Amplifier should I select for IR Photodiode ? What parameters are to be considered?
Actually I'm assigned to design a low noise preamp & apmlifier for IR Photodiode (PD34Sr) . So any help regarding this would be highly appreciated.
(5,391 Views)
Hi Semmas,
I don't have an overview over all amplifiers there are but I found these 2 helful links describing this topic.
http://www.linear.com/solutions/1785
http://www.ti.com/lit/an/sboa061/sboa061.pdf
I would also suggest you to cantact a manufactorer (e.g. linear technologies), describing your application and asking for a suggestion. If you have an paticular amlifier in mind it is much easier to find similar devices from other manufactorer.
I hope this could help you a little.
Kind regards,
Heinz
(5,358 Views)
