Multisim and Ultiboard
Why do I have extra entries in my MS hierarchy tab?
I have duplicate entries for schematic sheets in my hierachy tab of the design toolbox.
Why would this happen?
How can I fix it?
Does it even matter?
(3,361 Views)
Hi dbur,
I've never see or heard of this before. Is it possible to post the file so I can take a look or do you know how you got your design into this state?
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,338 Views)
I don't know how it got that way.  I just noticed it a few days ago.  Tiem Pham has a copy of the file you could look at.  He has been wortking on it for other reasons.  I cannot post it publicly.
Thanks.
(3,323 Views)
When I checked the files today the extra sheets are no longer there.  Must have healed itself by a re-boot or re-start or something.
(3,314 Views)
My bad, the one I checked again was not actually the file that had the problem.  The problem is still there in the actual file that had the problem.  I can send this to tech support (after I double check it again).
(3,240 Views)
