Multisim and Ultiboard
Why does Multisim keep my LEDs alive?
I have a circuit that keeps burning my LEDs. I sort of know the answer why, but is this normal Multisim behaviour?
Message 1 of 9
(6,807 Views)
Hello!
Some NI hardwares turn on and stay as "ON" position if you don't switch it off. Closing a programme or exiting an application doesn't switch LEDs back to "OFF"-position. You can switch the LED on. How about switch it off? Can you do it?
BR,
Make Nguyen
NI Finland Technical Support!
Message 2 of 9
(6,773 Views)
This was not my problem - if I don't add serial resistors to every LED line, the LEDs will be damaged (in real world).
Message 3 of 9
(6,769 Views)
Hello!
I am not quite following with you at the moment. Could you please specify your problems with more details. Adding pictures of your setups and codes might help me a lot.
BR,
Make Nguyen
National Instruments Finland Technical Support
Message 4 of 9
(6,764 Views)
Hi!
I am getting multisim, I just have the older version (11.0) so I couldn't open your ms12 file. Do you have ultiboard attached so you could evaluate your multisim simulation as well?
Br,
Make
Message 5 of 9
(6,747 Views)
Most parts in Multisim are ideal and the components rating are not part of the simulation. In Multisim, applying too much power to a component will not cause a simulation error but in real life, it will destroy the component.
Tien P.
Message 6 of 9
(6,734 Views)
Hello!
Sorry for not noticing your ms12 file before. I got your file open. I can see from your file that the LEDs are taking ~45 mA but the circuit are seeing them as 1.3 GOhm. Isn't this a sign of when LEDs are overloading? I mean, LEDs cannot consume that much of resistant right? Multisim just simulate the situation you got, you can input mega volts to the circuit and it is still functioning. I think Tien P. is right, the components are ideals and they will "never" break down.
BR
Make Nguyen
Message 7 of 9
(6,719 Views)
OK - thanks all! Nowadays I add a parallel capacitor at the output and measure current/voltage and add a serial resistor before LEDs.
Message 8 of 9
(6,714 Views)
I am glad that you got the solution. I will close this case for now. Is there anything else that we could help you out?
BR,
Make
Message 9 of 9
(6,709 Views)
