06-12-2008 01:00 PM
06-12-2008 02:12 PM
06-12-2008 02:32 PM
06-12-2008 02:47 PM
06-12-2008 07:28 PM
06-12-2008 07:52 PM
I don't mean to interject here, but maybe a simplistic analysis would help. Think of a PNP Transistor and the way it is hooked up with the emitter more positive than the base..As the voltage goes more negative with respect to the emitter the transitor conducts more. The same can be applied to JFET or MOSFET. With enhancements it is a little more difficult to visualize this. With 0V on the base the depletion layers keeps the FET in the off state untill the appropriate voltage is applied to "open" the channel for current to flow.
Also, on any FET the drain and source are interchangeable and that can be confusing when examining a circuit. You have to keep in mind the type of FET (P-Channel or N-Channel) you have and then determine which connection is the drain and which is the source based upon that knowlege.
This is how I keep it straight in my head. I do believe my thinking to be correct here.
I was trained to look at things in the simplest form and maybe my simplistic way of looking at things has been of help here
06-12-2008 10:44 PM
06-13-2008 05:52 PM
06-14-2008 02:22 AM
06-14-2008 11:38 AM
