Multisim and Ultiboard
Why is my Fourier Analysis failing
Why is my fourier analysis failing?   When I select fourier analysis a tab "analysis parameters" allows for "transient analysis."
(3,142 Views)
I was able to get the analysis to work by changing an option in the transient analysis settings inside the fourier analysis. You can take a look at the attached file.
Hope this helps.
Tayyab R,
National Instruments.
(3,129 Views)
