Multisim and Ultiboard
Why is this happening? SMPS
Hi guys has any one of you came across this problem on multisim. So I am trying to design a simple SMPS circuit using a 555 timer but for some reason the transistor after the first pulse just seems to not switch off at all i have even tried to replace it with a switch everything is OK until you switch it on and then off the voltage across the coil remains the same even though there is no connection. I am attaching the screenshots and the circuit file. And when I have removed the filter cap it get even weirder check it out. I have spent ages trying to figure why it does not work until i have tried to use a simple switch instead when i realized there's something else that i missed.switch offswitch offswitch onswitch onswitch off after it has been switched onswitch off after it has been switched on
(2,793 Views)
Hi Binvytas,
for some reason I cannot run the simulation on my computer so cannot test this but is there any reason you have a ground on the load next to the rectifier? This might not be the problem but I cannot see a ground in similar circuits so could you possibly check if anything happens if you remove it?
Kind Regards,
Riley Ilieva
(2,754 Views)
Here is an interesting channel where you can find very important information in the Electricity Sector:
(Acá hay un canal interesante donde se puede encontrar información muy importante en el Sector Eléctrico:)
https://www.youtube.com/ElectricityProjectUD
(2,748 Views)
