Multisim and Ultiboard
Why won't my rational polynomial VCCS work?
Here it is:
.SUBCKT MD0100_A 1 2 PARAMS a=0 b=0 c=.0373 d=-1.139 e=0 g=.0109 h=.24663 i=0 j=0 k=.0010883 l=.259684 m=0 n=0
B1 2 1 I={(a+c*(V(1)-V(2))+e*(V(1)-V(2))^2+g*(V(1)-V(2))^3+i*(V(1)-V(2))^4+k*(V(1)-V(2))^5+m*(V(1)-V(2))^6+o*(V(1)-V(2))^7)/(1+b*(V(1)-V(2))+d*(V(1)-V(2))^2+f*(V(1)-V(2))^3+h*(V(1)-V(2))^4+j*(V(1)-V(2))^5+l*(V(1)-V(2))^6+n*(V(1)-V(2))^7)}
.ENDS
This much simpler one won't run either:
B1 2 1 I={c*(V(1)-V(2))}
.ENDS
The unused parameters shouldn't cause harm ... should they?  Also, I tried to use the built in nonlinear controlled source device ... but it didn't work either.
I am using Multisym 9 - Student Version and any assistance will be very much appreciated.  Meanwhile ...
Regards to all,
- Craig
(3,702 Views)
HI Craig,
Version 9 is very different from the current product, especially in terms of supported SPICE syntax, so my comments do not apply to the current product.
Version 9 didn't support the PARAMS statement. You should substitute the PARAMS values in your expression, and remove the PARAMS statement. I think the rest should be supported. But if this doesn't solve the problem, let me know, and I'll try to find this older version to test this out.
By the way, the PARAMS keyword needs to be followed by a colon, for example
.SUBCKT MD01100_A 1 2 PARAMS: a=0 b=0 ....
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,682 Views)
Hello Garret,
Thank you for your helpful information.  I will try out your suggestion.
- Craig
(3,680 Views)
