Multisim and Ultiboard
Word generator output level
I'm trying MultiSim V10 and would like to generate "words" with the Word Generator, however it seems that the output is fixed to 5V logic and I'd like to have 10V in this case.
Is there a way to set/change the output level? (Of course it is possible to build a circuit which does this...)
Best wishes,
Rob
(5,950 Views)
robhol,
Unfortunately, this is a limitation in Multisim. This limitation is known and the developers are figuring out the best way to address it (the scope of the problem has deep roots).
Like you suggested, you can simply follow up the inputs with an ideal gain block.
Max
(5,939 Views)
I have looked at the word generator and I do not see a any way of changing its output level. I even looked in the main menus for anything to help and there is nothing there either.
Unfortunately, you probably going to have to find a way to boost this extenal to the word generator. Sorry, but the software won't let you change it from what I have seen.
Have a nice day.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(5,935 Views)
Ok, then I know - thank for the answers!!
/Rob
(5,916 Views)
