Multisim and Ultiboard
Would this circuit work? Why can't I use the multimeter?
Hi there, I just made a circuit, never used any modelling software like multisim, and I'm having smoe trouble.
In this attached circuit, I've tries to measure voltage in D1, R1, R2, etc., but I don't think I'm getting real values,
so I must be wiring it the wrong way. Can someone add some multimeters to the circuit and send me back,
as an example?
Would this circuit work, even with the poor made AC/DC change (and low AC frequency)?
And why am I getting these messages when I make the 'eletrical rules check':
    Error: Connecting 'Power to Bidirectional';   [V1 pin 2, Circuito 1]  to  [LED6 pin K, Circuito 1]
    Error: Connecting 'Power to Bidirectional';   [V1 pin 2, Circuito 1]  to  [LED3 pin K, Circuito 1]
    Error: Connecting 'Bidirectional to Power';   [D1 pin A, Circuito 1]  to  [V1 pin 1, Circuito 1]
(3,255 Views)
The ERC is a verification tool. With it you are able to find connections that you consider wrong. For example, if you want to be warned every time you connect a input to another input, you can configure the ERC to consider this connection as an error and be informed about it.
http://zone.ni.com/devzone/cda/tut/p/id/5579
Once you never used Multisim before, I'm sending to you a link with a bunch of tutorials you can read to learn more about Multisim.
Thanks.
Best Regards
Luciano Borges
Test Development Engineer
(3,215 Views)
