Multisim and Ultiboard
ad590 temperautre sensor database
Hi all,
where can I find a model (database to import) for temperature sensor ad590 and TMP01? I'm using multisim version 10.1.
regards
brazov
(7,867 Views)
Hi Brazov,
Multisim doesn't really simulate temperature and there are no components in the database for it.  What can use to emulate temperature are controlled voltage sources such as Voltage Controlled Voltage source, Voltage Controlled Current or Voltage Controlled Resistor.  Attached is an example.
Tien P.
(7,841 Views)
