Multisim and Ultiboard
bug? Multisin ERC on unconnected pins
In version 10.1, whenever I use the ERC option in Multisim to find unconnected nets, it won't report an error whenever a pin is ONLY connected to a bus (the net isn't connected anywhere to another pin)
Basically this happends every time when you redesign. You now have to be very carfull, if you remove something from a bus, i need to make sure i do it everywere.
(4,158 Views)
In Multisim 12, this is no longer the case (what it verifies is the net connection, so in your example, if the bus is not connected to anything, the ERC will treat the pin connection from a component to a bus as an "unconnected pin".
Kind regards,
Miguel V
(3,409 Views)
Wow, 4 years later it is fixed Smiley Happy
Sorry, but I've already switched to Altium Designer since the bugs in MultiSim 10 where just too many. Even tech support at NI couldn't help me out when a design was getting completly useless due to a (by support confirmed) bug.
(3,399 Views)
