Multisim and Ultiboard
bug report : copy schematic
Hi:
I'm testing Multisim 10.1 and I found an error when copy a schematic.
How to reproduce bug:
- Place CD4027 (FF JK) part A and part B. You have U1A and U1B
- Select All (Ctrl+A)
- Copy
When I paste image in other software (Word for example) appears U1A and U1B with correct labels, correct footprint pin names but symbol pin names are the same! (both have U1A pin names). I check this issue with other parts and have the same problem.
I use the copy function very often because the copy have a vectorized form. With this problem the only workaround is use the "Tools->Capture Screen Area" function but gives a bitmap image.
Sorry for my english
Javier
Argentina
(3,744 Views)
duplicated post
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(3,732 Views)
