Multisim and Ultiboard
bug report multisim 10.1
Hye,
I'd like to report a bug (at least what I think is a bug) in multisim ver. 10.1: (might be already reported, but I couldn't find it)
In steps:
Scenario 1:
- Create new schematic
- Add new subcircuit
- Add HB/SC connector to subcircuit
- Go to supercircuit
- Right click on subcircuit and choose "Edit Symbol/Title-block"
- Symbol editor opens and everything works fine
Scenario 2:
- Add BUS HB/SC connector to subcircuit
- Symbol editor doesn't open and multisim reports: "Unrecognized object found in subcircuit/hierarchical block symbol. Symbol cannot be edited."
Kind regards,
Olaf van den Berg
(4,131 Views)
I am not sure if this is a known issue for 10.1, but in 10.0 there was an issue with busses and subcircuit blocks. I have not tried it in 10.1 to see if it had been corrected, but from what you have posted, I would say that it hasn't been. At least, what you are describing sounds simular to the 10.0 problem.
Thanks for that and I am sure NI will look at this and hopefully either find a way around it or correct it in future updates.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,099 Views)
Dear Mr. van den Berg,
thank you very much for reporting this issue. I forwarded this to the circuit design R&D group by reporting it in a Corrective Action Request (CAR). It reported under request number; 134097.
Martijn S
NI Netherlands
(4,056 Views)
