Multisim and Ultiboard
bus text rotation
Anyone find a way to rotate text on a bus? I want my text to follow up and down the bus from top to bottom, can't figure it out........anyone try that?
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,342 Views)
If you are referring to Multisim, then I have not been able to do anything with the bus labels except move them around or lock them in position.. All the rotate and delete options are greyed out and unselectable, I even tried going into sheet properties and turning everything off there to see if I could get rid of the label so you could try and place text on it to do what you want None of this worked, so this may have to be a feature request.
Kittmaster's Component Database
Have a Nice Day
(3,341 Views)
hmm....since we can adjust the static text, I would guess this is a bug since it should follow the same rule set. Hopefully they will pick up this and add it to the list.
(3,335 Views)
