Multisim and Ultiboard
bus vector dialog box interface annoyance
This bus option makes life real easy, but one thing that is really needed is the dialog box size memory. I have 128 nets contained in one bus and I have to segment them out 8 lines at a time. But each time I have to do it, I have to resize the dialog box because the name and the amount of nets within the dialog are too squished.
It would be nice for MS to remember the size of the last dialog. This should mandatory for ANY resizable MS dialog box. Ones that are fix, obviously are not needed, but this simple add in will make life a whooooooole lot easier.
NI's thoughts?????
Message Edited by kittmaster on 11-26-2007 10:44 PM
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,159 Views)
Hi Chris:
I can see how this would be helpful. I have added this to our list of requested features.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,131 Views)
