Multisim and Ultiboard
cRIO Module examples in Utilboard
In the catalog pages for the cRIO Module Development Kit (MDK), NI states:
"You can find example layout templates in Ultiboard as well as mechanical templates stored in standard computer automated design tool formats."
I installed Utilboard and cannot find any layout example at all for these modules.
Has anyone found and/or used an example that describes the PCB layout?
All I am trying to accomplish is to embed some signal conditioning circuits into a cDAQ module shell, possibly using a small amount of 5V power, no other backplane or FPGA interaction...
Thanks!
(4,569 Views)
I checked in my old (v10) version of Ultiboard and found something, i don't know if this is what you looking for:
start a new project/design in Ultiboard.
The place a part:
Place ----> from database
then in the left screen select Ultiboard Master --->Board outline --->Compact Rio
there are 4 types of board templates in my database...
succes!
(4,558 Views)
Thank you!  That was (embarassingly) easy...
I couldn't get Utilboard to Export the file after placement, probably because I'm in Eval period.
But Capture Screen Area does well enough ofr me to have a template I can trial fit parts to.
(4,516 Views)
