Multisim and Ultiboard
can anyone tell me how to draw these pictures
i dunno how to draw the lower two circuits ...can anyone draw them for me ?
(5,077 Views)
Last circuit will look something like the picture attached. Circuit before it can be drawn in a similar manner. Just think through it a bit. It's not too difficult.
rgds,
skeatz
(5,048 Views)
can anyone tell me how to solve the two lower circuits please
(5,039 Views)
Convert resistors R4, R6 & R7 from delta-to-star. Let's call them Ra (top arm), Rb & Rc.
Calculate resistance (R5+Ra+Rb//Rc).
Now compute the equivalent resistance as seen from left of R2, looking to the right Req = (R2//(R5+Ra+Rb//Rc)//R3).
Current divider formed by R1 & Req.
You should be able to work out the value of current from here.
(5,028 Views)
the one above it is difficult because i dunno if the "X-shape" can be taken as a node or ithey are different wires!!
(5,012 Views)
If your drawing for cct 3 is correct (with a node/junction @ the center of the X), then it will be like mostafa_cct3-1. This is equivalent to the next cct that I have drawn, i.e. mostafa_cct3-2.
It's your drawing, only you can tell if it is drawn correctly (or ask your lecturer?). Calculating the current is simple in this case - just a matter of series/parallel resistors.
(4,958 Views)
