Multisim and Ultiboard
can't swap gate because pins have no "pingroup"
I tried to swap pins of a header (HDR type) with defined pins swap groups (after I editted the component in the database).
After transfering to ultiboard, I got the above message.
I tried to repeat this with a smaller header with only two pins, and this time it worked...
What am I missing?
There were no traces on the first header...
(3,793 Views)
If you can attach your design file, I will take a look to see what is causing the error.
Sharanya R
Market Development Engineer
(3,783 Views)
