Multisim and Ultiboard
cannot get instrument waveforms and readings to print, circuit does, overlapping message
I am not sure what version you are running but there was a bug with this message a long time ago. Try this:
1.  Go to the Control Panel>>Display
2.   In the Windows Display Properties dialog, select the "Themes" tab
3.  Change the theme to "Windows Classic".
If this doesn't work, select View>>Grapher and you should be able to print your result in here.  You can also do a screen capture and paste the instrument in Word and print from there.
Tien P.
(3,295 Views)
