Multisim and Ultiboard
capacitor simulation error
 Hi; I Have an problem;
When simulating  "time step too small " often occurs;  After Using Convergence Assistant; I can simulate but the output of XSC1 is not corrent , It include direct flow,
The capacitor C1 not filter dirent flow. and in "alteractive simulation settings" ->"initial conditions" is changed from "Automatically ..." to "user defined"
If I change from "user defined " to "Automatically ...", when simulating the simulation error dialog occurs.  the multisim version is 10.0
(4,433 Views)
Please attach your circuit.
Max
(4,411 Views)
Hi, Thank you for your anwser!
This is my circuit!   supplement at once: if change at "interactive simulation setttings"-->set to zero, output of XSC1 also include direct flow.
(4,395 Views)
Avoid re-build the circuit map, I post the circuit map directly.
summarize:  "interactive simulation settings" -> "set to zero"     result:     output have direct flow.
                    "interactive simulation settings" -> "user define"     result:     output have direct flow.
                    "interactive simulation settings" -> "DC operating ..."     result:     simulation error occurs: time step too small
                    "interactive simulation settings" -> "Automatically ..."     result:     simulation error occurs: time step too small
Would you like to explain the role of "time step" in multisim?
Thank you!
(4,391 Views)
There is a simple circuit about capcitor. the rusult is :
     "interactive simulation settings" -> "DC operating ..."     result:     output have no direct flow.
     "interactive simulation settings" -> "Automatically ..."     result:     output have no direct flow.
I do not know the reasons.  Please help me explain it.   Thank You!!!
(4,388 Views)
