Multisim and Ultiboard
cd 4047 model required
how to add the model of CD4047 IC in multisim 10 or please tell if i can get the component from any site or by you
Message 1 of 13
(24,323 Views)
There is a generic monostable available in Multisim and you can find it in the Mixed group under the Mixed Virtual Family.  If you are not sure how to hook up this component have a look at the attached file, the  A1 pin is positive edge trigger while A2 is negative, the pulse width is 0.693*RC. I'll be surprise if you are able to find the 4047 model online.
Tien P.
Message 2 of 13
(24,317 Views)
hi
you send the file for CD4047 can not be open...
 plz send the prefix for the file...
Message 3 of 13
(24,025 Views)
It opened for me. I have Multisim 10.1
Howard
Message 4 of 13
(24,013 Views)
Hi, this generic model have only 7 pins, in most of the circuits it is 14 pin, can any body please provide the componet for it
thanks
Kami
Message 5 of 13
(23,037 Views)
I'm new with this and I also need help with this model. I just found a CD 4047 model for LTspice, can it be converted to a multisim 10 or 11 model?
Message 6 of 13
(19,497 Views)
Hi Richard,
The file you attached is not a SPICE model, it looks like a netlist file and you can't use it to create a component.
Tien P.
Message 7 of 13
(19,443 Views)
i am using multisim 12.0
i want cd4047
how to get it
it is not included in the library
waiting for your reply
Message 8 of 13
(18,161 Views)
This part is not included in the Multisim database. You will need to see if a spice model has been made for this part by the manufacturer. You can check on the manufacturer's website. If you can find a spice model, you can use the article below to make a custom component in Multisim.
http://www.ni.com/white-paper/3173/en
Hope this helps.
Tayyab R,
National Instruments.
Message 9 of 13
(18,097 Views)
please any one can help me to find CD4047 or equivalent IC for inverter circuit
Message 10 of 13
(17,272 Views)
