Multisim and Ultiboard
cd4538 multivibrator
Hi
When i insert the both parts of the cd4538 then i always get the error message - there are two voltage sources in parallel- . It doesn´t matter if i make any wiring or not. When i insert only the two parts (A,B) of the cd4538 without any wiring the message will appear when i want to simulate.
Can anybody help me?
(4,767 Views)
When you have two voltage sources in parallel, often you'll get a problem.  The voltage sources could have been placed by you or it could be inside of a model.  I tried to replicate the problem based on your description but I could see the problem, if you post your file, it would be easier for me to see where the problem is coming from.
Tien P.
(4,740 Views)
