Multisim and Ultiboard
change pixel value RGB
Hi I'm looking for a simple way to change the value of some pixels inside a range of RGB. Example on the bottom. If u got a solution please can u show me the panels? Thanks a lot
(5,718 Views)
Hi there,
Thank you for your post, but something is not very clear here. Do you mean that you need to design the algorithm to circle these green spots out and turn them into other pixels? Or, do you just need some software tools like Photoshop to modify the picture?
Chen_T
(5,697 Views)
I'm sorry. I mean that i want to substitute the colour of some pixels (inside a range of values RGB that i select) with another colour (green in the example). I know how can I do it with matlab and photoshop but I would like to do with labview. I need the algorithm. Thank you. Sorry for my bed english 😄
(5,693 Views)
OK, I see. I am not very good at image processing using LabVIEW as well. But, to have your question been answered effectively, I recommend that you post this problem in the LabVIEW Boards.
http://forums.ni.com/t5/LabVIEW/bd-p/170
Chen_T
(5,690 Views)
Already done! But no reply.. thanks 😉
(5,687 Views)
