Multisim and Ultiboard
changing units in ultiboard
How do I change units in ultiboard? I want the units to appear in mm. If I go options > global preferences > dimensions / pcb design  and change the units from mil to mm, nothing happens and if I go back in, the units are displayed as mil again
(5,638 Views)
There are a few ways you can change the units. The easiet is to change it from the Toolbar. You will see there is a drop-down box where you can change the units. Please look at attached screenshot.
You can also go to Options >> PCB Properties. Under the Grid & units tab, change the unit.
Hope this helps.
Tayyab R,
National Instruments.
(5,635 Views)
