Multisim and Ultiboard
circuit of buzzer controller for 8 team quiz contest
can u design a circuit for buzzer controller for 8 team quiz contests using74ls75,74ls08,ne555,two input and gate,7805,5v regulator,bc548 npn transistor,ln4007 rectifier diode,rectifier
(5,922 Views)
Probably.
(5,920 Views)
can u please do it in multisim and ca u send me mail
(5,913 Views)
Accepted by topic author veerendra
Probably, you may find the following resources useful
Getting started with Multisim
http://zone.ni.com/devzone/cda/tut/p/id/10710
If you have a circuit designed in pspice you can design the same in Multisim too. Following tutorail may be of use.
http://zone.ni.com/devzone/cda/tut/p/id/5964
Ankur
(5,909 Views)
thank you ankur but the problem is i cannot find comonents in multisim software so what i have do how can i use other components instead of the components that have to be used
(5,902 Views)
and ankur how can i know what component can be used instead oof one component
(5,901 Views)
74ls75, 74ls08, 555 timer models are available in Multisim
For bc548 & ln4007 diode, you will need to create a custom componenet in Multisim. Please use the following tutorial
http://zone.ni.com/devzone/cda/tut/p/id/3173
Ankur
(5,895 Views)
