Multisim and Ultiboard
compiler fatal error in multisim
I am trying to make a blink led with PIC16F84 mcu. I've tried with 8052, 8051 too. Both gave this compiler fatal error.
My version of Multisim are 14.2 professional.
First of all, when i build my project, this prompt message pop up on the screen:
"The active project configuration project1 of MCU U1 is out of date.
Would you like to build it?"
I click in Yes
Then, a compiler error show on the Results tab.
"Fatal Error: Unable to start the compiler"
and the code didnt compile.
this is a freshy installation of multisim.
what should i do?
Message 1 of 8
(5,717 Views)
help me please
Message 2 of 8
(5,667 Views)
help, i did not find any talk about it in the search.
Message 3 of 8
(5,646 Views)
help me dudes... sorry my english.. iam brazilian
Message 4 of 8
(5,640 Views)
Hi gui__,
Except for some (minor) flaws your English is comprehensible, we can get the thought.
Other members of this forum may have not encountered this kind of problem or they might be busy with their own tasks so they can't provide the help that you need.
In my case I am only using Multisim Live (Free Subscription) so I don't have the necessary resource(s) to help you.
I think it's worth paying attention to your problem and the solution to this will help others too. I hope someone will be able to help solve your problem soon.
G. Goodwin
Message 5 of 8
(5,634 Views)
Hi G. Goodwin,
I'm glad that you though my english comprehensive, it's a good signal.
I 'll be awating for some clues related to this question.
Some further details: I'm trying to use the compiler with the following configuration as in the image
Cheers
Message 6 of 8
(5,621 Views)
Problem solved.
I had to go to C:\Program Files (x86)\National Instruments\Circuit Design Suite 14.2\hitech and execute the install of hitech compiler.
Apparently, Hitech compiler wasnt installed by default in my multisim.
Message 7 of 8
(5,609 Views)
I'm glad that you already found what hinders the compilation of your PIC(16F84) and 8051/2 code in Multisim. It's also a good gesture that you posted the solution, it will be helpful to others who will stumble with the same problem in the future.
Message 8 of 8
(5,578 Views)
