Multisim and Ultiboard
componet wizard
when i builde a componet model, i don't know the process detail,please tell me the next step
step 3:in the componet diagram,the rectangle's size can  not be changed?   because some pin name is very long,the two side pin name  overlap.
step4 :the pin type:Passive,what are "passive" meaning ?the enable or non enble pin?
pliease explain the detail.
in your web, the process of build componet is too simple!!
(3,789 Views)
Hi woshizhu,
Step 3: You can usually always make the rectangle bigger, that will give you more room to move things around. Once you have what you want, you can try to move everything to the upper left and resize the box.
Step 4: I honestly think those parameters are used for nothing more than some DRC checks, so they are mostly informative. They may have some purpose in simulation that I don't know about, but I sure haven't seen it make any difference.
Check out the link in my sig, I think it might have some help on creating components.
____
Ryan R.
R&D
(3,779 Views)
thanks for your answer
(3,768 Views)
