Multisim and Ultiboard
custom input signal from excel
Hi All
I have used a gauss meter to measure the flux density of a magnetic wheel (Aluminimum wheel with 40 magnets seperated by 9 degrees), the output of the gauss meter has been saved into excel. One colum is time the other is flux density.
How can i generate a signal based around this excel data in multisim. As the signal is sinousodial but each pulse has a different width and each peak and trough changes in amplitude i cannot use a AC_waveform in multisim.
I have attached the Excel data so you can see the waveform. I just need to know how i can get this into multisim.
PS i have multisim 14.0 and VirtualBench.
(4,168 Views)
(4,138 Views)
