Multisim and Ultiboard
differential vs. Single-ended connection
I want to acquire a signal from a photodiode, which its output is as current, in the following: you can find the link of that.
I'd like to know which type of connection should I select?Differential or single-ended?
Petar
(5,165 Views)
Hi Petar2015,
I am unable to see the link that you intended to use, so I don’t know very well which photodiode you are using. In the following link, you should be able to find a little more information about the different ways to wire inputs.
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
I would recommend you to use the single ended to acquire input of current. But if I were you, I would read through the document and analyze the ways to connect it with the diode you have.
Luis C.
(5,076 Views)
Petar,
First you posted to the signal conditioning board, which was incorrect. Now you've posted to Multisim, which is also incorrect. You need to work on your computer skills as well as hardware understanding.
(5,064 Views)
