Multisim and Ultiboard
drill via of pcb
Hi;
I'm working on a PCB of two alyers and i would to know how we can choose the drill (inner hole)and wall thckness of my VIA .
please if some one has an idea or imformations about this point mail me.
Thank you.
Best reguards.
(4,217 Views)
You can double click on your via in Ultiboard click on the Via tab. Here, you can choose to use custom via sizes as opposed to the ones that you set for the entire design in Ultiboard.
The Drill Diameter is the size of the inner hole
The Pad Diameter is the size of the via including the annular ring
Leave the Plated option checked unless you want to make a non conductive hole
Hope that helps.
Yi
Software Developer
National Instruments - Electronics Workbench Group
(4,193 Views)
hi Yyao;
thank you for your replay.
the method how i change the drill and pad size of via i know it.
but the problem is in wich parametre i choose the size of my via.
for example the relation between the size of via and the current or the track the we put it on.
thank you again.
(4,168 Views)
Edit:
Sorry, replied to wrong thread
Message Edited by yyao on 12-31-2008 01:23 PM
Yi
Software Developer
(4,158 Views)
Alternatively, you can set an option for the board which will cause all new via to be created in a custom size. To do this:
  1.  Click Options>>PCB Properties
  2. Under Vias, change the Drill and Pad diameters as appropriate
  3. Click OK
  4. All new vias will be created under the new settings that you just specified
 Does that work for you?
Yi
Software Developer
(4,154 Views)
