Multisim and Ultiboard
edge detection ckt
Hi guys,
I'm new to NI Multisim environment, I was wondering if I could design the below mentioned ckts and get the same (delayed) outputs. If you are reading this plz do reply ASAP.
(4,982 Views)
All logic models in Multisim contain non-zero delays. So if you wire your circuit as shown, it should produce a pulse as shown.
You can modify the delays by editting the model of the component (Properties dialog>>Value tab>>Edit model button)
Unless you are trying to simulate logic gates which you can directly purchase in discrete form (such 4009BD), I suggest you stick to components under "Misc Digital" group, and under the "TIL" family.
Max
(4,970 Views)
MaxNI, It doesnt seem to be working, I cant seem to see any delay in the logic analyzer...
(4,960 Views)
please share your circuit
Max
(4,951 Views)
