Multisim and Ultiboard
error in model LM293D - open collector property of output not implemented?
The comparator LM293D has an open collector output according to the datasheet.
I attempt to use that property to create a delay in the positive going response.
However, the output in the model goes hi without the external pull-up resistor that is required according to the datasheet and does not delay when attaching even a large capacitor to the minus rail.
Thanks for any help.
Jan
(5,714 Views)
Hello Jan,
Can you attach your actual Multisim schematic file?
This should allow me to have a first look at the your experiencing and should also allow me to evaluate what might be going wrong.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,687 Views)
Hello Jan,
Is this issue still active?
If yes, then please let me know.
Kind Regards,
(5,557 Views)
