Multisim and Ultiboard
error %s %s??? special problem
So trouble thing.Its likes the problem of "The temp"  .But the error said "%s %s"
Message Edited by Support on 06-20-2007 09:32 AM
Message 1 of 10
(5,520 Views)
Attach your circuit file and a description of what exact version of the software (Help >> About) are you using...
Nestor
Message 2 of 10
(5,517 Views)
Thinks.Please down the accessories.
Message 3 of 10
(5,516 Views)
What about the circuit file?... we would like to build the exact same circuit...
Nestor
Message 4 of 10
(5,513 Views)
any circuit shows the problem. The problem likes what change the system variable "TEMP" and "TMP".But in these ,the error show %s %s.
The simple circuit also show the problem. like this.
Message 5 of 10
(5,507 Views)
Who can help me !? Or my computer would never run the multisim2001!
Message 6 of 10
(5,475 Views)
As it makes little sense to be measuring an applied voltage, I'm assuming that is a current meter, that you're trying to measure current.  If that is the case, your error may be the error you'd have were this a real circuit.
A current meter, so as to not rob source voltage from the circuit under measurement, has very low impedance.  To clarify, it looks like a short circuit for all practical purposes.   As such, looking at your circuit, you may be shorting out your resistor and causing excessive current draw from your voltage source, a current draw that MultiSim can't resolve.  Current measurements must be made as they are in real life: in series, measuring the current THROUGH a device.
If this isn't the case, then I yield to others who may be more knowledgeable.
Message 7 of 10
(5,465 Views)
There are three things you can try:
1. Try the suggestion for the TEMP error. This is the KB about it: http://digital.ni.com/public.nsf/allkb/15526EB2464F3EDD8625722C00696BB0
Your Windows seems to be XP and localized into Japanese or Chinese if I'm correct, please note that Multisim 2001 was designed for Windows 98. Have you tried in another computer?
2. Are you logged in as an Administrator? You have to have Administrator privileges since Multisim 2001 is trying to create new files for the simulation log.
3. Every circuit needs a ground reference, please place a GND component so the Multisim engine will have a reference to create the nodes potential.
Nestor
Message 8 of 10
(5,450 Views)
Dear user, just to let know, as you can see on the above thread, we had to modified one of your postings, the attachment you included with the About Multisim window had your serial number printed, for your own security we deleted that attachment to protect your software license.
However, on this process, accidentally the other attachment with the error message was deleted as well, please accept our apologies for this. If you can re-attach only the error message you get we will appreciate it, otherwise there is not real need since you have specified in text the error message you get as well. Is up to you.
Thanks!
Nestor
Message 9 of 10
(5,434 Views)
Think you for your warmhearted help!
Thats also the problem of the Temp. Previously, I changed the variable of System, not the one of Users. After corrected, it run in the way!
Message 10 of 10
(5,416 Views)
