Multisim and Ultiboard
error when loading multisim
Structured Exception number 0xC0000005
Exception Report:
Exception code: C0000005 (ACCESS_VIOLATION)
Fault address:  01F0275A 0001:0001175A C:\Users\David\AppData\Local\Temp\nii7B68.tmp
Registers:
EAX:00000000
EBX:00000000
ECX:029BE514
EDX:002C6B80
ESI:029BE514
EDI:00000190
CS:EIP:001B01F0275A
SS:ESP:0023029BE4D0 EBP:029BE550
DS:0023 ES:0023 FS:003B GS:0000
Flags:00010246
Stack Trace
Address  Frame    LogicalAddr    Module    SymbolName + Offset
01F0275A 029BE550 0001:0001175A C:\Users\David\AppData\Local\Temp\nii7B68.tmp DllUnregisterServer + 4250
01EF3D7E 029BEA40 0001:00002D7E C:\Users\David\AppData\Local\Temp\nii7B68.tmp
01EF478D 029BEDA4 0001:0000378D C:\Users\David\AppData\Local\Temp\nii7B68.tmp
01EF4DA9 029BF29C 0001:00003DA9 C:\Users\David\AppData\Local\Temp\nii7B68.tmp
01EF5613 029BF61C 0001:00004613 C:\Users\David\AppData\Local\Temp\nii7B68.tmp
01F017E4 029BF7EC 0001:000107E4 C:\Users\David\AppData\Local\Temp\nii7B68.tmp DllUnregisterServer + 292
0048D22B 029BF8BC 0001:0008C22B E:\setup.exe
00464CB7 029BFBC0 0001:00063CB7 E:\setup.exe
00467CD8 029BFCA8 0001:00066CD8 E:\setup.exe
004CB441 029BFCC4 0001:000CA441 E:\setup.exe
005052F2 029BFD54 0001:001042F2 E:\setup.exe
004CDEF8 029BFD80 0001:000CCEF8 E:\setup.exe
004D6251 029BFDC8 0001:000D5251 E:\setup.exe
004D6434 029BFED8 0001:000D5434 E:\setup.exe
0056B34E 029BFF54 0001:0016A34E E:\setup.exe NI_MetaToolbox_MetaOutput_GetSharedGlobalData + 241150
004E878C 029BFF88 0001:000E778C E:\setup.exe
76864911 029BFFD4 0001:00043911 C:\Windows\system32\kernel32.dll BaseThreadInitThunk + 18
772DE489 029BFFD8 0001:0003D489 C:\Windows\system32\ntdll.dll RtlInitializeExceptionChain + 54
004E871D 772DE489 0001:000E771D E:\setup.exe
(3,894 Views)
What Multisim version are you installing?
What's you OS?
When you're going through the installation you will see something like step 1 of 24, where did it failed at?
Disable you virus protection software and see if this makes a different.
Message Edited by Tien P on 10-13-2008 01:22 PM
Tien P.
(3,874 Views)
Ver. 10.1 Windows vista 32 bit. I had the eval version on the computer but removed it using ad remove in control panel now i can't reinstall it
(3,860 Views)
This type of error is really difficult to figure out because we cannot replicate this problem.  Since you have Multisim successfully installed before, can you restore you system to a previous date.
Tien P.
(3,814 Views)
