Multisim and Ultiboard
forward voltage drop option
The vf option on the seven-segment displays are not always visible. How can I enter the vf when it's not available?
Message 1 of 13
(8,179 Views)
help please.
Message 2 of 13
(8,151 Views)
Some more information would be helpful.
  1. What are the component's you have selected?
  2. What version of Multisim are you running?
If possible, it is also helpful to post your file so I can take a look at it.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
Message 3 of 13
(8,138 Views)
I've tried Multisim 10.1 and 11.0 with same results. Attached is the Multisim file with 3 7-segment displays. 2 has the no Vf option and the other does.
Message 4 of 13
(8,131 Views)
I've tracked it down, and the Vf parameter was removed from the model in 10.1 as the model was removed. This parameter is now built in as part of the model. Please let me know if this is causing particular problems in your case so I can evaluate the new model better.
Garret
Message 5 of 13
(8,108 Views)
When the segment starts to flicker, the students would change Vf values, keeping the current limiting resistors the same. It's not a big deal that the Vf option is not there. We just pick a different LED.
Message 6 of 13
(8,070 Views)
I think you're hitting on part of the reason the option was removed. The option allowed you to modify the display so that its behaviour was inconsistent with reality. You now need to use appropriate current limiting resistors, but if you built the circuit, you would need to do this anyway.
Garret
Message 7 of 13
(8,062 Views)
I also in need to simulate my high power LED project using XM-L LEDs with following specs:
Vf = 3.0V to 3.1V
If = 1.0A to 1.5A
My project goal is to run the simulation of the LEDs with Vf = 3.08, but I cannot select desired forward voltage. I know this option was available in Multisim 10.0, but I'm runnng 11.0 and don't see forward voltage selection for any current LED modules in 11.0 version.
Can someone help?
Thanks.
Message 8 of 13
(7,492 Views)
Hi Almica,
Attached is the LED I copied from the earlier version, you can open the file and build your circuit around it.
Tien P.
Message 9 of 13
(7,474 Views)
How do you open this file in the online version of multisim
Thanks in advance,
Fabrizio
Message 10 of 13
(4,464 Views)
