Multisim and Ultiboard
ground of circuit
Hello everybody,i am an electrical engineer student and we are making a circuit in class.At this circuit we have an oscilator tha we want to make a triangle wave with 35kHz frequency and  0.8 volt p-p.(not from the output of the op-amp(tl074),but from th pin of copacitor.We use this circuit.At class we have as ground the -12 volts.how can i make the same thing at multisim and see it at the oscilloscope?thanks in advance
Message 1 of 13
(4,389 Views)
lay out your file from Mul'tisima ...
Message 2 of 13
(4,353 Views)
I should take as an exit a triangle wave,at lab with these values i had almost 35k frequensy and almost 3V p-p.I say again that at lab we took as ground -12Volts
Message 3 of 13
(4,349 Views)
It should be like this .. ??
Message 4 of 13
(4,344 Views)
or so .. ??
Message 5 of 13
(4,341 Views)
First of all thanks for your answers but i think tha you have made some changes at the circuit.The circuit is like this picture,at lab i remember that we put 2 smoothing capacitors.I dont know if that thing has to do with wrong asnwer.The thing that iam sure is that real ground is -12 volts and for c=10n,R=.1.22k,R1=100k and the other two resistors 10k each of them that i must have almost 35kHz and 3++ volts p-p with traingle wave
Message 6 of 13
(4,324 Views)
Sorry my mistake you are right but you just changed the values.The circuit is right but gives wrong numbers at oscillator.Maybe tha happens bacause i have not put the smoothing capacitors
Message 7 of 13
(4,321 Views)
... 35 kHz originate in this configuration ...
Message 8 of 13
(4,309 Views)
I really thank you for your time.I have some problems.
1)the big question is:why at lab i had 35Khz with 100k instead of 6.2k?
2)why at lab i had 3.2volts p-p and now i had almost 5?
I am not asking you to answer because i know gia tried a lot to helo but i cant understand what is going on
Message 9 of 13
(4,306 Views)
this is the exactly pdf that our university has given to us about the op amp
Message 10 of 13
(4,305 Views)
