Multisim and Ultiboard
highlight
Hi its' Mike again.
sorry to be a pain but I have a problem with nets on the schematic. They look as though they are joined with a junction but are actually not connected and have different net numbers.Is it possible to highlight a single net easily and clearly on a large schematc as I am going to have to check every junction.
Many thanks
Mike
(3,643 Views)
Hi Mike,
Select Reports>>Netlist Report to get a report with all nets used schematic and which pins are connected to it.
Tien P.
(3,637 Views)
Also you can find these in the spreadsheet. It wont' tell you the connections, but you can click on the net to highlight it so to speak in the schematic with little blue squares. It probably would be better to use the technique in the previous post. It may better help isolate you net that is giving trouble. I was just pointing out another option for you. and hope it helps.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,628 Views)
Also, along with turning "Show Net Names" to always on, you could right-click on a net and select "Change Color" and set it to something that really contrasts with the other nets. 🙂
____
Ryan R.
R&D
(3,625 Views)
