Multisim and Ultiboard
how do I cut off some slot on the outline
My board had to have a slot to support edge connector. How do I place a slot on the outline with Ultiboard?
(3,408 Views)
O.k. here we go.
Number one you will not be able to use the board wizard in this case to create the outline. You have to delete the current board outline, select board outline as the current active layer and then use the draw tools at the top of the screen  to manually draw the outline to your specifications.
I would strongly recommend using the place plygon tool as it seem to create the board outline a lot better than using the Line tool.
I hope this helps
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,406 Views)
