Multisim and Ultiboard
how do i import a netlist from orcad to ultiboard?
(4,704 Views)
I am going to post something I found on the internet concerning this subject that will help.
In OrCAD capture export the netlist to a Calay netlist format. Importing this netlist format to Ultiboard will be your easiest method of going from OrCAD to Ultiboard.
Just Click File>Open. Then your netlist should be available to Ultiboard for loading.
Be advised that I don't have Orcad so I don't know if the above will work. It should, but I have not tested it
You may be able to just load the Orcad's default output. Click File>Open and check to see if it is avalable for loading in the window. If it is there, then it is a file format recongnized by Ultboard and can be loaded. Otherwise, you will have to convert it to a recongized format as stated above.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,698 Views)
Jusr so you'll know. The advice that I posted about the Calay netlist format actually came from this forum (must have been before I came aboard). So I trust this information more now than before. You can try it and see if it works for you.
Have a Nice Day
(4,690 Views)
O.K. I am sorry about that. I was assuming you had Version 10. I am not sure about Version 2001's support for Orcad files. Someone else will have to comment on this since I have never used the 2001 version of Ultiboard.
Have a Nice Day
(4,676 Views)
This feature is not available in all versions, if you select FileàOpen and in the Files of type field if you don’t see a Calay netlist option then you don’t have this feature.
Tien P.
(4,597 Views)
