Multisim and Ultiboard
how to convert.ms11 to pdf or .tiff
I was wondering how i can convert my circuit (.ms11) format to a .tiff  or pdf format for plotting or presentation.
(11,186 Views)
You can save your design as an image by doing the following:
- On your design sheet select the whole design (Ctrl+A)
- Copy it (Ctrl+C)
- Paste it in MS Paint
- Save it as image format
If you have a pdf file converter like CutePDF writer, you can save the design as pdf by clicking file>print in Multisim menu and choose the converter as your printer.
Mahmoud W
(11,180 Views)
If you install software like CutePDF you can also print directly to PDF without converting the MS11 file to an image. Just print in MultiSim and set CutePDF as your printer.
Rik Prins
Rik Prins, CLA, CLED
Software Development Engineer
(11,147 Views)
I wonder whether some PDF converter or Tiff converter can help you with that? You can google it and select one whose way of processing is simple and fast to help you with the related work. Remember to check its free trial package first if possible. I hope you success. Good luck.
Arron
(10,476 Views)
