Multisim and Ultiboard
how to create a two pin terminal block connector in ultiboard
I just wat to how to create a 2 pin terminal block male connector in ultiboard.
Thank you
(6,503 Views)
Thank you for contacting us. I want to recommend you a tutorial on how to create custom components in Ultiboard:
Creating a Custom Component in NI Ultiboard
The part created in the tutorial is an IC with SMD pads, however, the same concepts apply for the creation of connectors.
I hope this helps.
Fernando D.
(6,491 Views)
