Multisim and Ultiboard
how to import user custom footprint in ultiboard?
I have two or more pc,so this pc may have many custom footprint(User database).
how to import user custom footprint in one pc,(have any feature like multisim .prz file)?
帖子被semaphore在 04-09-2009 09:39 PM
时编辑过了
(5,755 Views)
Accepted by topic author Gan.Wish
There are a couple of ways you can do this.
1. Copy the user database from one computer to the other. (You can find the path to the database in Options > Global Preferences on the Paths tab).  Then in Ultiboard, use Tools > Database > Merge Database to merge the data from the user database from the 1st computer into the other. This is the best way if you have a large number of footprints to merge.
2. Place the custom footprints in a design file (ewnet file). Then copy the file to your second computer. Open the file in Ultiboard, then use the Database Manger to import the footprints. Click Tools > Database > Database Manager. Select the target database. You will notice the "Add parts from the design to the database" button becomes active (it has a yellow plus sign with an arrow). Click Ok
Note: In this case, you do not want to use Tools > Database > Add Selection to Database. This will add the entire selection as a single reusable part, which is probably not what you want in this case.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(5,746 Views)
