 marxurs
			marxurs
			10-21-2011 05:15 AM
how to make the component place show as picture below? i am trying to make it on ultiboard. thanks for help
Solved! Go to Solution.
10-21-2011 09:25 AM
Hi Marxurs,
Use the polar grid, it's easier to place footprint in a circular orientation, this option is under Edit>>Properties>>Grid and Units, change the grip to "Polar gird".
10-26-2011 09:27 PM
thanks for help~, but i have a question need to ask again, how i can let them have the equal space difference? because the DRC keep give me error: " the leds are too close or overlapping each others" ..
10-27-2011 08:44 AM
Hi Marrxurs,
You can select the footprints you want to have equal spacing and then select the Edit>>Align>>Space Across or Down. This Align option is not in all Ultiboard versions and if you don't see it, double click on individual footprint and under the "position" tab, you can define the x-y coordinate where the component will go.
11-04-2011 01:32 AM
hi Tien P,
Here is a small question to ask, how i can draw the circuit track with this circle shape to connect component pins ?
11-09-2011 02:47 AM
anyone can advise me  ??
11-09-2011 08:57 AM
Hi Marxurs,
 In Ultiboard, there is an option to place lines at all angle and this is useful when working on a polar coordinates.  Select Options>>Customize User Interface, under the "Commands" tab select "Place" from the "Categories" window, next highlight "Place All Angle Line (Place)" under the "Commands" area,  hold the left mouse down and drag this option and drop it somewhere on your toolbar to place a icon.  If you prefer, instead of placing an icon on your toolbar, you can create a shortcut key.  Select the "Keyboard" tab in the Customize dialog and then locate the Place All angle lines and assign the short cut key for this option.
11-09-2011 08:44 PM
greatest thanks for ur help~
i am just new learner into this software, so lots of questions i cannot get answer.
thanks for ur help again ~~
